18f452 with mikrosd card
buddhikaneel
I use MikroC Pro and PICKit2. Can anybody tell me how to do this
for (i=0; i<16;i++){
save (i) in mmc card
and also read saved data when necessory.
thanks
Here is a project which utilizes a SD card and MikroC, however the code require to use a MMC is virtually the same:
MikroC provides an array of library routines which greatly simplifies the coding required.
Take a look under the libraries tab on the MikroC page.
MMC Library and MMC FAT16 Library
BigDog
I already see the library in mikroc pro. But i'm new for programming. Can just say code sample.
No problem. The Data Logger project should get you started in the right direction. However, you need to be aware that MMC and SD cards are 3.3v not 5v. Therefore you'll either need to find a breakout board with a 3.3v voltage regulator or build your own. They both use a SPI interface.
BigDog
Thank you very much for your post and what kind of regulator can i read. Is there regulator like 7805?
