How to calculate Slew Rate for Differential folded cascode opamp.....??
ASHUTOSH RANE
KOZICODE
How to calculate Slew Rate for Differential folded cascode opamp.in cadence can anybody tell me ....??
thanks in advance...:smile:
ASHUTOSH RANE,
After tarnsient simulation you have to do direct plot differential output signal from Results->directPlot-Transient->transient difference
Than you can deriviate this expression to calculate slew rate of differential output.
Or use this expression in cadence command line:
deriv((v("/OUT1" ?result "tran") - v("/OUT2" ?result "tran")))
Best Reguards
hi alex
i found the derivative accoring to formula u given ....
now with this wave form and defination of slew rate we can find slew rate as maximum rate of change of output .....i got such a value equal to...
SR+ =229e6.
SR- =-227e6
CL=1pF
but these are very high values right ....??
have i done any mistake in calculation of maximum slope??
SR+ =229e6.
SR- =-227e6
CL=1pF
SR+ =229e6 = 229 V/µs which means 7.64ns for your 1.75V step. Zoom into one of your step edges and verify!
hi ASHUTOSH RANE
There is no any mistake in calculation,
all right!
