headman333
Member level 5
I have rewired my honda motorcycle, changed all busted lights, make horn functional again, everything about lighting is OK. But, I found out that the alternator leads does not output any voltage, so the effect is that it doesn't supply AC voltage to the regulator/rectifier circuit, which in turn does not charge the battery.
My problem is how do I fixed the alternator to give an AC output?
