[SOLVED] How to select I/O pad ,please give some guidelines
1.System Speed(CLK)
2.In/Out/Inout
3.pull high/pull low
Anyone can give some documents about I/O pad selection?
thanks!!!!!!
slow rate , driver strength, current, speed requirement. etc.
Hi seseandy,
IMO, selecting an I/O pad is very subjective, it basically depends:
1. Max speed of the pad
2. input/ output / bi-directional
3. with or without open drain output
4. driving strength/ current/power/ wire load of the pad (this usually rely on how much current to drive the circuit).
5. pull-up, pull-down or none
6. with or without schmitt trigger
7. with or without ESD protection
8. Size (it might be critical in some design).
regards,
always smart
hi Always_Smart,
Can you elaborate further on purpose of the Open-Drain output and Schmitt Trigger features..?
giggs11 said:
hi Always_Smart,
Hi giggs11,
YOu need a pull-up resistor for the Open-drain output, in I2C standard this kind of output is particularly needed.
For the schmitt trigger, it usually use in the clock input to prevent "spike" in the input signal.
regads,
always@smart
