1. #1
    seseandy
    How to select I/O pad ,please give some guidelines
    thanks!
    •   AltAdvertisement
  2. #2
    Member level 5
    Points: 2,843, Level: 12
    Join Date
    Mar 2004
    Posts
    89
    Points
    2,843
    Level
    12
    Re: How to select I/O pad ,please give some guidelines
    1.System Speed(CLK)
    2.In/Out/Inout
    3.pull high/pull low
    •   AltAdvertisement
  3. #3
    Full Member level 2
    Points: 2,735, Level: 12
    Join Date
    Jul 2004
    Greater Noida, India
    Posts
    125
    Points
    2,735
    Level
    12
    Quote Originally Posted by seseandy
    thanks!
    The Selection criteria is
    1) Speed (frequncy of operation, single ended or differntial)
    2) Type of load.
    3) Power
    •   AltAdvertisement
  4. #4
    seseandy
    Anyone can give some documents about I/O pad selection?
    thanks!!!!!!
  5. #5
    Full Member level 1
    Points: 1,835, Level: 9
    Join Date
    Jul 2004
    Posts
    104
    Points
    1,835
    Level
    9
    slow rate , driver strength, current, speed requirement. etc.
  6. #6
    Full Member level 4
    Points: 5,478, Level: 17
    always@smart's Avatar
    Join Date
    Feb 2002
    ASIA
    Posts
    195
    Points
    5,478
    Level
    17
    Hi seseandy,
    IMO, selecting an I/O pad is very subjective, it basically depends:
    1. Max speed of the pad
    2. input/ output / bi-directional
    3. with or without open drain output
    4. driving strength/ current/power/ wire load of the pad (this usually rely on how much current to drive the circuit).
    5. pull-up, pull-down or none
    6. with or without schmitt trigger
    7. with or without ESD protection
    8. Size (it might be critical in some design).
    regards,
    always smart
  7. #7
    Member level 3
    Points: 1,897, Level: 10
    Join Date
    Apr 2004
    Posts
    57
    Points
    1,897
    Level
    10
    hi Always_Smart,
    Can you elaborate further on purpose of the Open-Drain output and Schmitt Trigger features..?
    Thanks
    •   AltAdvertisement
  8. #8
    Full Member level 4
    Join Date
    Feb 2002
    ASIA
    Posts
    195
    Points
    5,478
    Level
    17
    Quote Originally Posted by giggs11
    hi Always_Smart,
    Thanks
    Hi giggs11,
    YOu need a pull-up resistor for the Open-drain output, in I2C standard this kind of output is particularly needed.
    For the schmitt trigger, it usually use in the clock input to prevent "spike" in the input signal.
    regads,
    always@smart
