+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 2
    Points: 474, Level: 4
    Join Date
    Oct 2010
    Posts
    20
    Points
    474
    Level
    Please help using sdf file in Synopsys and ModelSim?
    Hi every one
    I am calculating Area, power and timing in ASIC using Synopsys Design Compiler and ModelSim. After Anlyzing and elaborating the design then applying constraint and Compiling, I saved the sdf file (using Design Compiler) as follow:
    write_sdf ./SYNOPS/SOURCE/test_defult.sdf
    when I use ModelSim Command:
    vsim -sdfmax /kkk_tb/uut=./SYNOPS/SOURCE/test_default.sdf work.kkk_tb
    I got the following Errors:
    ** Error: (vsim-SDF-3250) ./SYNOPS/SOURCE/test_default.sdf(60): Failed to find INSTANCE '\output_reg[0] '
    ** Error: (vsim-SDF-3250) ./SYNOPS/SOURCE/test_default.sdf(57): Failed to find INSTANCE '\x0_reg[0] '.
    Please any suggestion ??
    thanks
    •   AltAdvertisement
  2. #2
    Join Date
    Oct 2010
    Posts
    20
    Points
    474
    Level
    Re: Please help using sdf file in Synopsys and ModelSim?
    Hi
    I could solve the problem by deleting the following line from my code:
    change_names -rule verilog -hierarchy
    thanks
    •   AltAdvertisement
  3. #3
    Member level 3
    Points: 1,521, Level: 8
    Join Date
    Mar 2009
    Manchester, UK
    Posts
    59
    Points
    1,521
    Level
    8
    I dont think it is actually the answer.
    Make sure there is no command between write and write_sdf in your synthesis script
    •   AltAdvertisement
  4. #4
    Advanced Member level 3
    Points: 6,706, Level: 19
    Join Date
    May 2008
    Shang Hai
    Posts
    972
    Points
    6,706
    Level
    19
    yes, please check synthesis script before you do run!
