Could you be a little more specific, define the port as....? What compiler are you using?
For Keil the following may contain:
LPC214x User Manual
u mean which language i use??
i use c programming...
As i know, i can define pic directly like PORTA=CAR. Is i define lpc as the same way??
I was actually referring to the C compiler company, Keil, IAR, GCC, etc.
But yes, assigning a port a value would be similar to the procedure used with a PIC.
The actual C compiler and the associated header file would dictate the naming convention for the port.
Does this info help answer your question?
BigDog
