problem with assign in verilog
gmish27
what's wrong with the following code:
module test
input a,b,c,
output y
wire x;
assign y = a & x;
assign x = b & c;
endmodule
it synthesizes and simulates too but I read their will be a mis-match between the pre and post synthesis. care to explain???
Just wanted to know where u have read or can you attach the doc which supports your statement.
I really don't see any issue with the above code.
I also tried with vcs and did not found any problem and I also did not see any change after synthesis. its remains 2-input AND.
Not in this case. If you try using non-blocking assignments in always loop with clock you may see the difference.
