[SOLVED] VHDL Error Multiple declarations of "+" included via multiple use clauses"
blooz
Advanced Member level 2
India
The Exact Error is reported as ...
line 43.Multiple declarations of "+" included via multiple use clauses; none are made directly visible
particular Line is
G <= A + B + UNIT;
Re: VHDL Error Multiple declarations of "+" included via multiple use clauses"
I guess you are trying to add signed or unsigned types and you included both numeric_std and std_logic_arith. Both files declare a signed and unsigned type and the arithmetic functions for them. Because of this, it doesnt know which one to use, so wont let you use either without specifiying which ones:
signal a : numeric_std.unsigned(7 downto 0);
signal b : numeric_std.unsigned(7 downto 0);
signa g : numeric_std.unsigned(7 downto 0);
g <= a numeric_std.+ b;
I would stick with just numeric_std because it is a real standard, std_logic_arith is not.
Reactions: blooz
    blooz
