+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 36
  1. #1
    Newbie level 6
    Points: 1,604, Level: 9
    Join Date
    Jun 2004
    Posts
    12
    Points
    1,604
    Level
    9
    Microsoft VC++ or Borland C++ builder ? Which one?why?
    i think it's a war between microsoft fans & opposition groups!
  2. #2
    Advanced Member level 2
    Points: 5,237, Level: 17
    papyaki's Avatar
    Join Date
    Apr 2002
    France
    Posts
    539
    Points
    5,237
    Level
    17
    Re: Microsoft VC++ or Borland C++ builder ? Which one?why?
    In the compagny where I am working, people use VC++ to write applications from scratch and use Borland to write applications including graphical functionalities.
    All these people say that neither VC++ nor Borland is better. It depends on the need they have.
  3. #3
    Full Member level 5
    Points: 4,033, Level: 14
    Join Date
    Mar 2002
    Posts
    301
    Points
    4,033
    Level
    14
    Hi. Borland C++ Builder is easily way to write programs.
    Only least piece of programs can't made with it.
    Best Regards.
    •   AltAdvertisement
  4. #4
    Full Member level 3
    Points: 4,825, Level: 16
    Kit-the-great's Avatar
    Join Date
    Mar 2002
    Russia
    Posts
    150
    Points
    4,825
    Level
    16
    As I know, VC++ generate more optimized code and works more correctly (especially in real-time programming), but Builder have the better service and more useful for GUI programming.
  5. #5
    Full Member level 1
    Points: 2,103, Level: 10
    Join Date
    Nov 2004
    Posts
    101
    Points
    2,103
    Level
    10
    hi,
    use vc++ its better and supported by microsoft as u progrma in windows also the help integration the debugger is integrated with the api, i,e if u want to find out last error number u can by @err,hr
  6. #6
    Member level 4
    Points: 1,904, Level: 10
    Join Date
    Sep 2004
    Posts
    70
    Points
    1,904
    Level
    10
    I use VC++ & # for MS-windows programming. nobody understand windows better than microsoft!
  7. #7
    Full Member level 1
    Points: 2,647, Level: 11
    Join Date
    Jul 2001
    Posts
    98
    Points
    2,647
    Level
    11
    and Builder X ??? is better???
  8. #8
    Advanced Member level 5
    Points: 16,636, Level: 31
    Join Date
    Jul 2001
    Oberon
    Posts
    1,897
    Points
    16,636
    Level
    31
    I am a Borland Builder fan. I think it is much more productive and easier to use than MS. What takes a day in MS can be done in an hour in Builder.
    It also more closely complies with the standard for C++. Microsoft has poor support for templates and partial template specialization.
  9. #9
    Junior Member level 1
    Points: 1,517, Level: 8
    Join Date
    Oct 2004
    Posts
    15
    Points
    1,517
    Level
    8
    C++ Builder (not X) uses VCL-Classes (esp. for GUI).
    Using VCL is very easy but has not got features like MFC or .NET offer.
    There is no big difference for WIN-API or MFC-Programming between C++Builder and VC++.
    VC++ Compilers are a bit faster than Borlands but with C++Builder X you can use Intel Compilers(the fastest of all).
    Builder X does not support VCL (no RAD).
    •   AltAdvertisement
  10. #10
    Member level 1
    Points: 1,846, Level: 9
    Join Date
    Aug 2003
    Posts
    32
    Points
    1,846
    Level
    9
    to reply this question, we must know what you want to do?
    do you wanna write database apps or device drivers? two extreme point.
    main point, if you want more detailed things, VC++ is better. 'more detailed' also means 'more harder'.
    i like vc++ because i can find almost everything related vc++ (sample, code, lib etc) using the internet.
    •   AltAdvertisement
  11. #11
    Member level 5
    Points: 1,915, Level: 10
    Join Date
    Nov 2004
    Posts
    87
    Points
    1,915
    Level
    10
    if you design a GUI application, builder is ideal choice, for it contain a large number of useful component, and it is convenient to use.
    if you design a rock-bottom application, you can choose VC++, for it is much closer to hardware segment.
  12. #12
    Points: 8,778, Level: 22
    Join Date
    May 2002
    Posts
    1,184
    Points
    8,778
    Level
    22
    why borland did not give any new version from BCB 6,It is along time (3 years) that there is no new version.why?
  13. #13
    Full Member level 2
    Points: 2,313, Level: 11
    Join Date
    Nov 2004
    Posts
    135
    Points
    2,313
    Level
    11
    I prefer to VC++, for operating system belongs to microsoft.
    operating system provide it much more interface than bulider.
    and with the development of system, it must be more stable and powerful.
  14. #14
    Join Date
    Oct 2004
    Posts
    15
    Points
    1,517
    Level
    8
    Quote Originally Posted by 7rots51
    I think RAD is not planned for new BCB versions...
    Delphi and c#builder are the only ones supportig RAD(don't know about Borlands JAVA Techniques...)
  15. #15
    Newbie level 1
    Points: 1,460, Level: 8
    Join Date
    Nov 2004
    Posts
    Points
    1,460
    Level
    8
    power flow control
    optimal power flow control
  16. #16
    Member level 4
    Points: 1,920, Level: 10
    Join Date
    Dec 2003
    Posts
    70
    Points
    1,920
    Level
    10
    I think you can use VC IDE, but you should use the complier of intel.
  17. #17
    Full Member level 5
    Points: 3,262, Level: 13
    Join Date
    Jun 2004
    Posts
    278
    Points
    3,262
    Level
    13
    VC++. Mainly because you could obtain the latest version free from Microsoft website. I'm not sure if Borland provides thier latest compiler, but I think they do provide some version back.
  18. #18
    Points: 11,875, Level: 26
    bobcat1's Avatar
    Join Date
    Jul 2002
    Posts
    Points
    11,875
    Level
    26
    Hi
    I have worked with BORLAND C++ builder for many year's.
    And I think i'ts a very good programming tool easy to learn and the best tool for RAD- rapid application development
    HMI it match better then VC++
    Regrads
    Bobi
    •   AltAdvertisement
  19. #19
    Full Member level 4
    Points: 2,493, Level: 11
    Join Date
    Oct 2004
    Posts
    212
    Points
    2,493
    Level
    11
    If you want to develop a real application which should compatible with previous versions and OS (windows), you have to select VC++.
    If you want to write codes in a professional way and use all utilities of OS, choose VC++.
    If you worked on windows programming professionally, you can select VC++.
    If you want to write Visual codes based on C++ but you are not good at windows programming concepts, you can choose Borland C++ (Borland Builder).
    If you want to develop a GUI program in the quickest way, select Borland C++.
    If you don't worry about OS problems, i strongly recommend you to use Borland C++.
    Regards,
    KH
  20. #20
    bhongtip
    So there're VC++ programmer more than C++ Builder ?
