+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Member level 2
    Points: 835, Level: 6
    Join Date
    Mar 2010
    INDIA
    Posts
    47
    Points
    835
    Level
    Need help for Zuken CR-5000
    Hi Everyone,
    I am new to Zuken products. I have experience in PADS, OrCAD, Cadence and Altium.
    Now I have to create some schematics in Zuken CR-5000 and create their repective PCBs. Uptill now I have created some schematics, but failed to convert them to PCB (Though they are very simple).
    So can anyone help me for the design entry and the PCB process. I also wanted to know the GERBER file extension used in CR-5000
    Wiating for your comments,
    Regards,
    Spidyelectronics.
    •   AltAdvertisment
  2. #2
    Full Member level 3
    Points: 3,719, Level: 14
    hotwaterwizard's Avatar
    Join Date
    Apr 2004
    USA
    Posts
    177
    Points
    3,719
    Level
    14
    Re: Need help for Zuken CR-5000
    They do offer training classes
    Scheduled Training Courses | Zuken
    They also offer free downloads that may help you
    CR-5000 Downloads | Zuken
    Look for Printed Circuit Board, Production Preparation and Manufacturing Download
    Try this to open the Gerber file
    How to Verify Gerber Files
    1 members found this post helpful.
  3. #3
    Member level 2
    Join Date
    Mar 2010
    INDIA
    Posts
    47
    Points
    835
    Level
    Thanks Hotwaterwizard,
    I went through all these downloads and various help documents, but unfortunatly non of it contains any process information. So it will be very help full, if I can get the process of creating PCB and linking it with respective schematic.
    Regarding gerber files, I open some sample PCB files and try to generate gerbers from it, which results in the generation of "*.phd, *.phl and *.ptb" files. So I wanted to confirm that whether it is right or wrong. I tried to open these files in GerbMagic, but it gives me error that it is not 274X format.
    Thanks.
  4. #4
    Full Member level 3
    Join Date
    Apr 2004
    USA
    Posts
    177
    Points
    3,719
    Level
    14
    Try some of these FREEWARE Programs
    Downloads - PCB Design
  5. #5
    Advanced Member level 5
    Points: 12,436, Level: 26
    Achievements:
    7 years registered
    Join Date
    Feb 2010
    UNITED KINGDOM
    Posts
    1,955
    Points
    12,436
    Level
    26
    Gerbers are text based so can be manually checked, standard Gerber extensions are .gbr .ger .spl .plt, most Gerber software will parse a file before it loads it so any extension can be used, this is so it can determine whether it is a Gerber format file, then the version, and finaly the format (leading, trailing, integers:decimals etc).
    Cant be more specific on CR-5000 as I only use Cadstar.
    •   AltAdvertisment
  6. #6
    Member level 2
    Join Date
    Mar 2010
    INDIA
    Posts
    47
    Points
    835
    Level
    Thanks Guys for your valuable posts.
    As I mentioned earlier, I have created schematic design. And now I wanted to convert it in to the PCB design. So the main problem infront of me is, I am using Zuken product first time in my life. So I am not atall aware of it's basic flow.
    I am facing defficulties in the following things
    1. I have done with schematic design. Now what will be the next process for PCB designing?
    2. Is their any way by which we can link the schematic and PCB? (By which we can make any changes in PCB according to changes in schematic or viceversa).
    3. I have used varioous tools like Altium, Protel, Cadence, OrCAD, Allegro etc. In these tools, the gerber file extensions are *.gbr, *.art, *.pho, *.GTL etc and all these are 274X formats. But when I tried to generate gerber files from the CR-5000 sample PCB designs, it gives me "*.phd, *.phl and *.ptb" files, out of which *.phd is the main gerber file (I guess). So I just wanted to know, whether I am right or wrong.
    Also, if possible to anyone of you, can you please guide me through process or suggest some tutorials available.
    Waiting for your reply.
    Thanks.
    •   AltAdvertisment
  7. #7
    Advanced Member level 3
    Points: 9,513, Level: 23
    cyberrat's Avatar
    Join Date
    Jun 2001
    In the sewers of the U.K.
    Posts
    883
    Points
    9,513
    Level
    23
    Are there no tutorials that come with CR5000 ?
    Please do not PM me questions that are better asked in the PCB forum :)
  8. #8
    Member level 2
    Join Date
    Mar 2010
    INDIA
    Posts
    47
    Points
    835
    Level
    Quote Originally Posted by cyberrat View Post
    Their is no single tutorial present with CR5000. So I am going with the help documents, one sample PCB and one sample schematic.
  9. #9
    Member level 1
    Points: 577, Level: 5
    Join Date
    Dec 2011
    Posts
    40
    Points
    577
    Level
    can CR5000 rev12 and rev13 support windows 7?
  10. #10
    Newbie level 1
    Points: 38, Level: 1
    Join Date
    Oct 2012
    Posts
    Points
    38
    Level
    spidy...
    make sure you do have the license in generating the gerber data.Same with the feature of schematic capture
    •   AltAdvertisment
  11. #11
    cyberrat's Avatar
    Join Date
    Jun 2001
    Posts
    883
    Points
    9,513
    Level
    23
    Quote Originally Posted by icko View Post
    spidy...
    What sort of comment is that for a first post?
  12. #12
    Junior Member level 1
    Points: 1,450, Level: 8
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    19
    Points
    1,450
    Level
    8
    Zuken should provide you with paper manual when you purchased the license.
    If not I'm sure you can contact your customer support rep at Zuken.
  13. #13
    Achievements:
    7 years registered
    Join Date
    Feb 2010
    UNITED KINGDOM
    Posts
    1,955
    Points
    12,436
    Level
    26
    If your employer expects you to do designs with a system then they should provide training. You mention having used numerous packages for PCB design, this in my opinionis not a good way to work, you cannot master PCB design and a PCB design package in a few days or weeks. Ihave used allwgro and Pads inthe past both for periods of two years plus, but I would not put themon my CV because I do not consider that I know them well enough. You realy need to use one package and learn that properly, and that requires training. Zuken do provide training for CR-5000, get some.
