how to make padmaster in PADS layout ? (that is pads holes or drill holes open)
scriptx007
Member level 1
india
Hello every body , i m good designer in orcad and altium . in orcad or altium there is option of "keep drill holes open" . but in PADS layout there is no such option . i want top or bottom side layer with drill holes open . when i make postscirpt file this option is not available. dont tell me to do tht from gerber file. can anybody tell me how to achive that in PADS layout . sample is attached just chk it out
  • Top Layer.pdf
Hi, ia m also phasing the same problem. Please help me out if you have found the solution.
I could get it for throughhole components and few vias also but vias which are under copperpour are not opening.
Thans,
Vamsi
hi vamsi115,
i didn't found solution in PADS. but in cam350 we can do it. by changing drill hole colors. or else in GCprevue it is easy. wen u import drill file in gcprevue. it directly gives u padmaster.
