length matching in allegro16.2
selvakumar.m
Junior Member level 1
how to check the length mathching in allegro 16.2
Click on i symbol(Make sure that only net is enabled in Find) and then select specific net.The total length is displayed.Otherwise go to Tools->quick reports then select etch length by layer report.Here you get all signal length report.By comparing this you can check the length match of signals.
    V
ok.thank u.i get it.can u say what is the main reason for going from 2layer to 4 layer boards
