raylito
Junior Member level 1
Charging super capacitor with USB - current limiter?
I have a torch that is powered by 2 50Farad Super Capacitors in Series. I use the USB port of a PC to charge the super capacitors using a 10ohm resistor to limit the possible maximum current (5V/10Ohms) to 500mA.
The torch charges up nice and quickly at first, but then as the voltage gets higher it drops according to Ohms law, so when the super capacitor voltage is at 4V, I am only charging with USB Voltage - Super Capacitor voltage / 10Ohm resistor = 100mA. As it charges more and more, the rate gets worse and worse and the last 0.5volts takes forever to charge.
I see a number of parts on the internet for limiting USB current to say 500mA or selectable. These parts are often difficult to obtain or they are almost impossible to solder by hand as they have no pins and the pads are underneath the part.
Is there a way of charging the super capacitors much quicker. A way of forcing the current into it perhaps? Or alternatively limiting the current to 500mA at all times in the charging - this would not help the charging rate when it gets to over 4V though, but the fast charging at the start of the charge would make up for this.
Any suggestions?:lol:
