martijn
cant resolve multiple constant drivers
I was trying to create my first program, and I was able to resolve most errors, but I don't know how to resolve this one:
Error: Can't resolve multiple constant drivers for net d0[3] at countminutes.v(63)
Error: Constant driver at countminutes.v(85)
I've looked it up and the problem is that I write to a register twice, or something like this.
In my opinion this error is wrong, but according to quartus II web edition it's a problem. can anyone tell me what I could do to fix it?
The code should count up seconds when 'clks' is pulsed. when 60 is reached it should reset to zero.
when seconds is pulsed and running==1, the counter should decrease and when it reaches zero, it should pulse 'minutes' and reset to 59 (probably this doesn't work 100% correctly but thats a ploblem I'll solve later).
thanks in advance,
martijn
code:
module countminutes
// {{ALTERA_ARGS_BEGIN}} DO NOT REMOVE THIS LINE!
clkm, minutes, running, d0, d1, zero
// {{ALTERA_ARGS_END}} DO NOT REMOVE THIS LINE!
// Port Declaration
// {{ALTERA_IO_BEGIN}} DO NOT REMOVE THIS LINE!
input clkm;
input minutes;
input running;
output [3:0] d0;
output [3:0] d1;
output zero;
// {{ALTERA_IO_END}} DO NOT REMOVE THIS LINE!
reg [3:0] d0;
reg [3:0] d1;
reg zero;
always @ (posedge clkm)
begin
d1<=d1+1;
if(d1==4'd10)
begin
d0<=d0+1;
if((d0==4'd2)&(d1==4'd4))
begin
d0<=4'd0;
end
d1<=4'd1;
end
end //line 63
always @ (posedge minutes)
begin
if(running==1'b0)
begin
d1<=d1-1;
if(d1==4'd15)
begin
d0<=d0-1;
if(d0==4'd15)
begin
zero<=1;
d0<=4'd3;
end
else
begin
zero<=0;
end
d1<=4'd2;
end
end
end //line 85
endmodule
thanks in advance,
martijn
code:
module countminutes
// Port Declaration
input clkm;
input minutes;
input running;
output [3:0] d0;
output [3:0] d1;
output zero;
reg [3:0] d0;
reg [3:0] d1;
reg zero;
begin
d1<=d1+1;
if(d1==4'd10)
begin
d0<=d0+1;
begin
d0<=4'd0;
end
d1<=4'd1;
end
end //line 63
begin
if(running==1'b0)
begin
d1<=d1-1;
if(d1==4'd15)
begin
d0<=d0-1;
if(d0==4'd15)
begin
zero<=1;
d0<=4'd3;
end
else
begin
zero<=0;
end
d1<=4'd2;
end
end
end //line 85
endmodule
