JohnG300c
I'm working on a DDR2 interface which requires lots of pull-up resistors. My design uses x8 resistor arrays. In order to minimize trace stub lengths I would like to be able to utilize pin-swapping between the resistor arrays such that, after having been placed on the PCB, the resistor array pins could simply be attached to the closest signal needing termination. In other words, I would need to re-assign a net from one x8 resistor array pin to another pin in the same or another x8 resistor array.
The Altium Designer PDF documentation (AP0138 ) states that part swapping can only been done if the parts being swapped are all sub-parts of the same part.
Is there a solution to this problem or will I have to manually swap net labels in my schematics and push the changes back to the PCB?
Thanks.
Thanks.
