Sending high frequency pulse with 8051
sysysy
Member level 3
May i know is it 8051 manage to send high frequency square pulse such as 40khz or 25 micro second for a period pulse out from their pin? (ultrasonic use purpose)
as i know, 8051 only support max 24mhz crystal and after divide 12cycles per instruction mean every instruction it will take 0.5micro.
in this case, if we use interrupt to make the pwm for 40khz pulse. then is it work?
Any idea or amendment?
thanks.
regards.
sysysy
use timer to generate the delay of 25 micro seconds
Reactions: chuduc
    chuduc
That mean interrupt every 12.5 micro seconds set high the pin and another 12.5 set low the pins...it shud be work rite?
A 50% duty cycle clock can be programmed to come out on P1.0. ranging from 61 Hz to 4 MHz at a 16 MHz operating frequency. juste take a look at datasheet page 10.
�(65536RCAP2H, RCAP2L)
  • 8XC51_8XC52.pdf
