10pf N1500 caps needed
neazoi
Advanced Member level 6
Greece
hello I need some ceramic disc caps 10pf N1500 temperature coeff. Does anyone have available?
Google "electronic component suppliers" or "ceramic disc capacitor".
Right... I knew how to do this. I was wondering if any member has a few to supply
These have an orange/orange top but I cannot find any on ebay. I have made some tests on some bad quality ceramic disc capacitors and their value changes too much when I heat them with a hair dryer.
What is the amount of changing when a capacitor is N1500? Also should it's value change to less capacitange as heated or to more?
1500 is a voltage rating isn't it? Try C0G or NP0 types for temperature stability and precision.
No, N1500 is negative temperature coefficient 1500ppm, which I need for my application. NP0 has zero temperature coefficient and C0G is the material used.
Try google "temperature coefficient of capacitors" to find more on this.. or google is not working in your country...? ;)
