P16f877a interface to PC via USB by Mikroc code
yes
it is awm 3100v
---------- Post added at 17:15 ---------- Previous post was at 17:01 ----------
yes
it is awm 3100 V
ok..when u use pot-lin.it have 3 pin..first is for +5V..second is signal to PIC analog pin..third is -ve..
i couldn't use pot-lin
How can i generate C-T signal represents the flow from it?
Is buffer needed in the circuit?
nope. the max 232 will also act as buffer
i still have a problem of how to sample the signal
