Analysis of shunt feedback amplifier
shadimichael
Newbie level 1
Denmark
Hello,
I am doing some hand calculations of a simple shunt feedback amplifier (common source topology with resistive feedback).
To take loading effects into account, I am following the y-parameter approach described in Grey and Meyer. My transistor model includes gm, ro, Cgs, Cgd and Cdb.
As expected, the final expression of the loop gain contains two LHP poles (input and output) and one RHP zero. However, the input pole does not show the Miller effect (?), it only shows Cgd in shunt at the output.
I do not see how the Miller effect can be obtained when using y-parameters, since you have to short the output to calculate y11 (which contains the input pole). Am I missing something here? or is y-parameters approach incomplete?
Thanks.
