chromatik
Member level 4
- Joined
- Aug 15, 2006
- Messages
- 78
- Helped
- 2
- Reputation
- 4
- Reaction score
- 4
- Trophy points
- 1,288
- Location
- Switzerland
- Activity points
- 1,882
ADS Momentum : Simple differential (sport problem)<-NO !
Dear all,
I have a simple layout, with 2 conductors and 4 ports.
These 4 ports are differentials, the substrate definition is a FreeSpace layer, a Dielectric layer (let's say Alumine), and another FreeSpace_0 layer with open boundary. So, no ground plane.
The substrate calculation worked fine, so the meshing.
Then after, the simulation too.
But when I want to up Create/Update the equivalent component, Momentum returns this error:
I thought it was a port problem, but I cannot explain the error.
And as I quit this project and restart , I have an "AEL error" message.
Do you have an idea where is the problem?
I previously tried deleting ATF file, with no more success.
Any help would be appreciated.
Thanks a lot !
Regards
Dear all,
(C:\ADS2008U1\prj\Test\networks\Test_parallel_4-ports_diff.ael line 27, column 23 in load)
operand missing for operator
(C:\ADS2008U1\prj\Test\networks\Test_parallel_4-ports_diff.ael line 27, column 1) Test_parallel_4
function definition not completed
(C:\ADS2008U1\prj\Test\networks\Test_parallel_4-ports_diff.ael line 30, column 1)
illegal context for statement block
(C:\ADS2008U1\prj\Test\networks\Test_parallel_4-ports_diff.ael line 88, column 3) return
only allowed within function definition
error compiling AEL file
C:\ADS2008U1\prj\Test\networks\Test_parallel_4-ports_diff.atf
loading old compiled AEL file
(C:\ADS2008U1\prj\Test\networks\Test_parallel_4-ports_diff.ael line 27, column 24 in dereference) ports_diff_artwork
variable/function undefined
compiled AEL file not loaded
Thanks a lot !
Regards
