+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 3
    Points: 523, Level: 4
    Join Date
    Oct 2010
    Posts
    26
    Points
    523
    Level
    test bench in vhdl for set up & hold time violation
    i want test bench in vhdl for set up & hold time violation ,can anybody help me?
    •   AltAdvertisement
  2. #2
    Newbie level 5
    Points: 591, Level: 5
    Join Date
    Nov 2009
    Posts
    9
    Points
    591
    Level
    Re: test bench in vhdl for set up & hold time violation
    First of all, you must use the synthesized netlist, and not the actual verilog/vhdl file you must have written.
    Second, you must have a rigorous input vector of all possible input combinations.
    Something to be highlighted here is that the testing must be exhaustive - which means, many iterations using the input vector, w/o taking time outs between iterations.
    After this, if there are setup and hold violations, you should get some warnings when you simulate using the synthesized netlist.
    I hope this helps.
    •   AltAdvertisement
  3. #3
    Points: 8,890, Level: 22
    Achievements:
    7 years registered
    Join Date
    May 2010
    Marin
    Posts
    1,485
    Points
    8,890
    Level
    22
    uselly, the STA is here to check this knid of violations, and I didn't understood why you want to find or to check the setup & hold violation with a testbench?
    As written by ssti85, you need to be very rigorous with your input vectors, and with a timing netlist.
    •   AltAdvertisement
  4. #4
    Join Date
    Oct 2010
    Posts
    26
    Points
    523
    Level
    thanks ,but i want the vhdl test bench code because i have to submit it in my assignment
  5. #5
    Newbie level 5
    Join Date
    Nov 2009
    Posts
    9
    Points
    591
    Level
    its not very difficult to do that.
    You must have written normal test benches. Just put that in a for loop. and repeat the loop certain number of times (say a avg value of 1000 or so).
    Plus, in each iteration, try to take a different set of inputs. This usually should be done, so you get a better estimate of the the avg. power.
    Else, you can always take the same set of inputs and do all the iterations.
