scorrpeio
Full Member level 5
So here goes the problem definition...
a tank should have 2 sensor mounted at 75% and 25% empty/filled level. The tank will contain water whose level at 75% and 25% of tank capacity should be identified by the system and the motor should be turned on or off accordingly i.e if water level falls below 25% filled, start the motor to fill the tank and if water level exceeds 75% mark, stop the motor.
I have been suggested to use 89s52 controller which I am okay with. I can design the flow chart of the project and write the code also, but...
I dont know which sensor to use to detect water level
Because, whatever I may use, it must be cheap and should keep water away/isolated from current.
Can anyone tell me names of some cheap sensors which can detect water level???
---------- Post added at 18:21 ---------- Previous post was at 18:07 ----------
I have already searched through google, but cudnt get sensor which keep water isolated from current during working.
I have also read the similar topics on this site...but they didnt have apt solution
