+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Advanced Member level 2
    Points: 6,007, Level: 18
    samcheetah's Avatar
    Join Date
    May 2004
    Pakistan
    Posts
    646
    Points
    6,007
    Level
    18
    What is the application of SCR crowbar?
    ive read somewhere that an SCR crowbar is a protective circuit that protects equipment from over-voltages.
    i wanted to ask that where does this type of circuit find applications. what type of equipment have SCR crowbar protection. is this type of protection still used or is it outdated. what are the pros and cons of using SCR crowbars for over-voltage protection.
    •   AltAdvertisement
  2. #2
    Advanced Member level 1
    Points: 5,008, Level: 16
    Join Date
    Jan 2003
    Posts
    424
    Points
    5,008
    Level
    16
    crowbar overvoltage protection
    SCR crowbar protection circuit is used in Laboratory bench power supply units (etc.,) providing variable (not fixed) DC output voltages. Before feeding the DC output to the user developed circuit under test, one sets the crowbar voltage varying knob to a voltage required for the operation of circuit under test. In case the DC output voltage varying knob-setting exceeds that of crowbar set voltage, the device under test will be protected from the damage by switching off the DC output.
  3. #3
    Full Member level 3
    Points: 3,266, Level: 13
    Ante's Avatar
    Join Date
    May 2004
    Posts
    169
    Points
    3,266
    Level
    13
    scr crowbar
    These are frequently used in PSU:s for HAM radio equipment. If something goes wrong in the PSU the crowbar cuts of the supply before the radio circuits get damaged.
    Ante
  4. #4
    samcheetah's Avatar
    Join Date
    May 2004
    Pakistan
    Posts
    646
    Points
    6,007
    Level
    18
    scr application crowbar
    okay thanx
    nice to see u here ante.
    one thing more. which topology of the SCR crowbar is preffered. the one with the zener diode that sets the reference, the one with the BJT that sets the triggering level or the one with the comparator.
    •   AltAdvertisement
  5. #5
    Join Date
    Jan 2003
    Posts
    424
    Points
    5,008
    Level
    16
    crowbar voltage
    The one with the comparator is relatively more precise....
  6. #6
    Full Member level 5
    Points: 2,680, Level: 12
    Join Date
    Mar 2004
    Posts
    243
    Points
    2,680
    Level
    12
    scr applications crowbar
    I have thought that crowbar mode of operation for an inverter is when we short leg of it in order to make that input fuse act and protect it.
  7. #7
    justin999
    crowbar scr
    in ic chip, because the field oxide is so thin that it can be damaged by electrostatic destroy,so we add some electrostatic protection circuit in pads. SCR is a good type electrostatic protection circuit,
    pros small area
    cons higher trigger voltage
    •   AltAdvertisement
  8. #8
    samcheetah's Avatar
    Join Date
    May 2004
    Pakistan
    Posts
    646
    Points
    6,007
    Level
    18
    scr protection
    isnt that overcomed by using an op-amp for the triggering
  9. #9
    Banned
    Points: 1,757, Level: 9
    Join Date
    Feb 2007
    Posts
    110
    Points
    1,757
    Level
    9
    powersupply using scr schematic
    plz visit
    radio-electronics.com/info/circuits/.../scr_over_voltage_crowbar.php
