svia
Member level 3
Hello
I have an important doubt about how to measure with an Anechoic Chamber. My question has to do about where to place the antenna under test (AUT).
Having an anechoic chamber: there is a broad band antenna in the side wall, in front of this antenna, in the Chamber, we have to position our AUT. This AUT has to be aligned, but how??
Imaging that we want to measure a square patch antenna feed by a microstrip line in the middle of one of its sides. This is our AUT. We want to measure it in the Anechoic chamber.
How should be placed? The center of the squere patch should be the same as the center of the broadband horn antenna that will be use to measure?
I have found something about the center phase point. ¿Antennas should be centered at this point always? How can be defined this point?
I hope is clear enough
Thanks
Thanks
