+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Points: 484, Level: 4
    Join Date
    Jun 2010
    f-55/659 ganesh nagar delhi 92
    Posts
    Points
    484
    Level
    interface printer to 8051
    respect to all
    i am working on a project DYNAMIC QUEUE MANAGMENT SYSTEM
    this is my engineering final year project..
    for that i need to interface printr to my 8051 microcontroller..
    any body who knows..plz help..
    •   AltAdvertisement
  2. #2
    Full Member level 5
    Points: 3,404, Level: 13
    Join Date
    Dec 2002
    Posts
    281
    Points
    3,404
    Level
    13
    Re: interface printer to 8051
    More information is needed.
    What type of printer is this?
    What is the printer interface (USB, serial, standard Centronics parallel)?
    If the printer 'host-based', meaning that it relies of drivers on the computer-side for processing, then your job is going to be quite difficult.
    If you can choose your own printer, find an older dot-matrix type that is NOT host-based. Look at the specifications to make sure that it will work under DOS. These types of printers are dead simple to run from a microcontroller, as all of the processing is done by the printer itself, and you just have to send it ASCII data and twiddle a few control lines.
    •   AltAdvertisement
  3. #3
    Join Date
    Jun 2010
    Posts
    Points
    484
    Level
    as u said that it is easy to interface dot matrix printer..
    but is it possible to interface a thermal printer to 8051..
    because my project demand to print 80-100 words
    and it will look good..
    plz help..
    u recomend me the printer modle..
