Sine Wave peak to peak value detector.
unexpert
Newbie level 5
Sine Wave
I input a function generator to my board so that I could get a sine wave.
However, the problem is, I need to program my board in such a way that it could detect the peak-peak value and display it on the LCD screen.
How do I go about doing this?
By the way, I'm using PIC18F2620.
I've done some reading where I need to include pwm and stuff but that didn't help much.
Hope someone here could give me some help.
Thank You.
Sine Wave
If you want to detect the peak value of a sine wave you can either use an analogue peak detect circuit and read that with an ADC in the PIC, or digitise the sine wave as quickly as possible in the PIC and look for the maximum value. Whether that will work depends on the PIC ADC maximum sample rate and the frequency and amplitude of the sine wave.
Keith.
Sine Wave
If the waveform is known to be a sine, you don't actually need a Vpp measurement. You also can calculate Vpp from averaged rectified value or Vrms.
Sine Wave
measuring Vpp is not that difficult. it is probably easier not to assume the incoming waveform to be sine.
most likely, you will need to scale the input and then level shift it. After that, it is simply continuously adc'g the input waveform, and finding out the highest / lowest voltage in a rolling window.
