always84
Member level 1
Hello
I'm using PLI in modelsim to generate a saif back file to Synopsys , because I want evaluate my switching activity. When i Load my project in my testbench, called main.v (this is a Verilog project), these warning are issue:
** Warning: (vsim-PLI-3003) /dati/test4x4_conDMA_preSIN_30giu/main.v(758): [TOFD] - System task or function '$read_lib_saif' is not defined.
# Region: /main
# ** Warning: (vsim-PLI-3003) /dati/test4x4_conDMA_preSIN_30giu/main.v(759): [TOFD] - System task or function '$set_toggle_region' is not defined.
# Region: /main
# ** Warning: (vsim-PLI-3003) /dati/test4x4_conDMA_preSIN_30giu/main.v(760): [TOFD] - System task or function '$toggle_start' is not defined.
# Region: /main
# ** Warning: (vsim-PLI-3003) /dati/test4x4_conDMA_preSIN_30giu/main.v(761): [TOFD] - System task or function '$toggle_stop' is not defined.
# Region: /main
# ** Warning: (vsim-PLI-3003) /dati/test4x4_conDMA_preSIN_30giu/main.v(762): [TOFD] - System task or function '$toggle_report' is not defined.
# Region: /main
How can I use PLI? I've check my modelsim.ini and this seems to be correct? I'm loosing some detail? thanks for hepling me
# Region: /main
# Region: /main
# Region: /main
# Region: /main
# Region: /main
