How should I apply PSS/PAC of Cadence Spectre for VCO
alizadeharand
Member level 3
cadence pac run for vco
I am about to run a Pac for vco!
i want to insert a current source instead of noise source and see the gain.
how can i do this?
Insert it in your schematic.
Re: cadence pac run for vco
What do you mean?!!
alizadeharand said:
What do you mean?!!
"it" means "a current source".
You yourself describe like following.
What do you mean by "Pac" ?
I can't understand a meaning of it even from "cadence pac run for vco" at all.
There are many simulators which have analysis called as PAC.
Always describe vendor's name and tool's name which you use as tool or simulator.
If you mean PSS/PAC of Cadence Spectre, erikl's reply very makes sense.
Also I can't understand why you refer "noise source" in PAC analysis.
Do you understand PSS/PAC analysis correctly ?
Corresponding analysis of Pnoise is PXF analysis not PAC analysis.
See https://www.designers-guide.org/Forum/YaBB.pl?num=1263203132/1#1
