The clock stability is usually specified the drift that me be observed in the frequency. PPM indicates the stability and hence cost.
+- 100ppm in a 1 MHz clock indicates the frequency may be between 999000 to 1000100 Hz at any given time the clock is powered. This may be either temperature or aging specification.
BRMadhukar
