availability multiple Power supply
Shreehari
Member level 4
mangalore
Power supply
Hello
I am having a circuit which has 3 different power upplies i.e +15v,-15v,and 0-5v.
I have a 6 circuits as such.But I cannot bear different power supplies for different circuits.Is there is any powersupplies which comes with 5-6 outputs?what are the parameters I should consider while doing these condition?
Its common to sell/construct a 3-fold pwr supply as your first part of+/-15V & 5V_you will find lot of switcher moduls on web...
In my opinion is a 6-fold supply not to find.
You should check your system pls_maybe you can use the same voltages 2-times_, or build self a set of individual regulators, but be care with power sequence!
Its well possible that some circuits needs exact sequencing at power up & down!!
You must use than a extra sequencer IC.
K.
    Shreehari
