+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 4
    Points: 1,585, Level: 9
    Join Date
    Dec 2009
    Posts
    78
    Points
    1,585
    Level
    9
    Resistor waste energy
    Resistor is found in a lot of circuits, however, are they actually making waste of energy? since they are just heating up itself!!
    Let say a resistor in a voltage divider and a resistor in series with a LED just for dropping the supply voltage
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 36,491, Level: 46
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    Re: Resistor waste energy
    This is correct. However, in many cases the cost of the wasted energy is less than the cost of the components that would replace it.
  3. #3
    Advanced Member level 1
    Points: 4,606, Level: 16
    Achievements:
    7 years registered
    Join Date
    Jan 2006
    Singapore
    Posts
    425
    Points
    4,606
    Level
    16
    Agree...
    Resistor component is for regulating/control purpose.
    Energy is consumed for the purpose.
    I guess we cannot run away from it.
    Everything have resistance.
    •   AltAdvertisement
  4. #4
    Full Member level 1
    Points: 1,365, Level: 8
    Join Date
    Jul 2010
    Pakistan, Rawalpindi
    Posts
    105
    Points
    1,365
    Level
    8
    resistors have other functions like RC couples and filters....
    they dont just waste energy
    •   AltAdvertisement
  5. #5
    Member level 4
    Points: 1,302, Level: 8
    akshay_d_2006's Avatar
    Join Date
    Jul 2009
    Mumbai
    Posts
    76
    Points
    1,302
    Level
    8
    Blog Entries
    They also play an important role in producing a voltage across it... when the o/p in current..
    Eg: In an current gain (amplifier) ckt, when you need o/p as a voltage, then you need to collect it with a load resistance... here resistance plays an imp role...
    Agree @siongboon:
    They also act as regulating devices...
    Say you dont want current to flow through a particular branch, you fill it up with a resistance so that current does not enter it.....
  6. #6
    Full Member level 4
    Points: 2,693, Level: 12
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Pakistan
    Posts
    223
    Points
    2,693
    Level
    12
    many times we have to connect a resistor in circuits just because to low down the voltage. it is the requirement to drive components that have small voltage ratings.
  7. #7
    Member level 4
    Join Date
    Jul 2009
    Mumbai
    Posts
    76
    Points
    1,302
    Level
    8
    Blog Entries
    Yes.
    And that is bcoz some components cant handle tat much of voltage, in terms that, it cant handle this much of power..... and thus heat..produced by it (power dissipation) So we do that before It enters the components...
    We also add resistances (add or subtract>>Series r parallel) so as to match the i/p--o/p impedance... That is called as impedance matching and is done so that maximum power can bee transferred from source to the load
    •   AltAdvertisement
  8. #8
    Full Member level 1
    Join Date
    Jul 2010
    Posts
    105
    Points
    1,365
    Level
    8
    also they are needed for the production of voltage in accordance with the ohms law
  9. #9
    Points: 40,458, Level: 49
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,790
    Points
    40,458
    Level
    49
    Quote Originally Posted by luckyvictor
    Did you hear about the sentence "conservation of energy"?
    With other words: This "waste" of energy by heating up a resistor is exactly what we want (because it cannot be avoided). We cannot take out energy from the voltage source and deliver it to a (for the sake of simplicity) resistive circuit without consuming this energy in form of heating up.
