Results 1 to 7 of 7
    Newbie level 5
    Points: 965, Level: 7
    Dec 2009
    9
    965
    7
    Derivative of Bessel Function in Matlab
    hi there,
    i'd like to know how to get the derivative of first kind Bessel Function and the derivative of second kind of Bessel function in Matlab.
    Thanks!
    Points: 10,710, Level: 24
    Sep 2001
    Argentina
    1,131
    10,710
    24
    Please explain.
    Do you need to obtain symbolic expressions or to perform numerical calculation?
    Z
    Newbie level 5
    Dec 2009
    9
    965
    7
    I need to perform numerical calculation like you said
    thanks
    CZ
    Newbie level 6
    Points: 642, Level: 5
    May 2010
    13
    642
    Re: Derivative of Bessel Function in Matlab
    See http://ceta.mit.edu/ceta/comp_spec_func/mcjylv.m
    it should calculate the derivative of Bessel of first and second kind!
    Sep 2001
    Argentina
    1,131
    10,710
    24
    Exact formulas for the derivatives can be obtained symbolically. With symbolic toolbox in Matlab, the following lines give it for the first kind (put besselk for the second kind):
    syms z;
    syms nu;
    diff(besselj(nu,z),z)
    The results are:
    -besselj(nu+1,z)+nu/z*besselj(nu,z)
    -besselk(nu+1,z)+nu/z*besselk(nu,z)
    (The same can be found in math books or tables.)
    Then, use built-in besselj and besselk functions.
    I hope this is what you need.
    Z
    Newbie level 2
    Points: 17, Level: 1
    Mar 2013
    17
    Hi zorro,
    what if "z" is also a function of two variables, for example, z(x,y)? thanks...
  7. #7
    Sep 2001
    Argentina
    1,131
    10,710
    24
    Hi ozly,
    Then the above is still valid.
    If what you want are the derivatives with respect to x and y, then apply the chain rule.
    Z
