+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 2
    Points: 1,225, Level: 7
    Join Date
    Oct 2006
    Posts
    23
    Points
    1,225
    Level
    7
    Electricity Generator
    I want to change moves (right and left) to electricity.
    Is there a generator can do this or sensor?
    •   AltAdvertisment
  2. #2
    Super Moderator
    Points: 49,672, Level: 54
    Achievements:
    7 years registered
    keith1200rs's Avatar
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    I do not understand what you want. Are you looking for something to convert an oscillating movement into electricity - like some watches?
    You could use a DC motor as a generator, but if your movement is oscillating then you would probably need to rectify the voltage produced.
    Similarly, you could pass a magnet through a coil, like a solenoid. Again, the voltage will need rectifying as it will change sign with the direction.
    Keith.
    I started life with nothing and I've still got most of it left. (Seasick Steve)
    •   AltAdvertisment
  3. #3
    Full Member level 5
    Points: 3,601, Level: 14
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Minnesota USA
    Posts
    297
    Points
    3,601
    Level
    14
    Re: Electricity Generator
    Google: shake flashlight
    Then use the guts of a "shake" flashlight:
    http://www.youtube.com/watch?v=rczWjuwZVFA
    ken
    •   AltAdvertisment
  4. #4
    Advanced Member level 5
    Points: 20,433, Level: 34
    Achievements:
    7 years registered
    Join Date
    Apr 2008
    EU
    Posts
    2,331
    Points
    20,433
    Level
    34
    I believe, that these isnt other as a normal generator(as Keith proposed too)_you have a moving magnet (or an electromagnet) in front of a plain coil or even inseide a round coil...
    K.
