Pheetuz
Full Member level 3
Hi folks.
I have been doing a project for uni where i am using shift registers to convert a 4bit number to serial and then back to parallel.
I have written the code below and simulated it, and it seems to work fine, however when i have actually built the circuit it is not functioning at all as expected.
-This is only the first shift register of the pair ... the number being concatinated onto the original signal is essential to the functioning of the second shift register.
The output is not changing when i apply a clock pulse to the clock input, I think it may have something to do with me not setting temp to a value before i initialise the code but am really not sure.
Any help is greatly appreciated.
/Pete
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Shift_reg is port (
bin : in unsigned(3 downto 0);
sout : out std_logic;
load, clk : in std_logic );
-- attribute pin_numbers of Shift_reg: entity is
-- "bin(0):2 bin(1):3 bin(2):4 bin(3):5 load:6 sout:19";
end Shift_reg;
architecture reg of Shift_reg is
begin
Right: process (clk, bin, load)
variable temp : unsigned (7 downto 0);
begin
if rising_edge(clk) then
if load = '1' then temp := (bin&"1101");
else temp := temp srl 1;
end if;
end if;
sout <= temp(0);
end process Right;
end reg;
/Pete
