what are the optimization techniques in DSP?
naresh850
Full Member level 3
Hello Guys,
I want to optimize the C code that will run on Blackfin DSP.
what are the optimization techniques that I have to used in optimization? or in generally how to optimized the C code.
Regards,
Naresh
Friends
start discussion on this topic,
how to optimize the c code on DSP platform
regards,
Naresh
Hi naresh,
There are several techniques for optimization using Blackfin.
1. You need to understand the algorithm which you are implementing.
2. Then you need to choose the instructions which could be used for that algo.
3. Blackfin has concept of load instruction which can be done parallely with DAG (any compute).
4. So get your Number of Instruction to be computed for your algo and based on that decide on your Load and compute instruction paralley.
5. You also need to take care of stall such that it should not increases your cycle count.
6. You can use PRINT_CYCLES count to see your cycles count of your algo function
If anybody have any material regarding optimization C Code on DSP platform then kindly please share it with me or send it to me on naresh850 at gmail
regards
