[SOLVED] how to calculate log2(n) in verilog
UFK
Member level 3
Pakistan
Hiii
can someone please help me to calculate log base 2 in Verilog. What i need to do is to simply calculate the log base to of a variable n. Please help
function integer clogb2;
   input [31:0] value;
   integer 	i;
   begin
      clogb2 = 0;
      for(i = 0; 2**i < value; i = i + 1)
	clogb2 = i + 1;
   end
endfunction
    UFK
Thanks alot RBB. I hope my code starts behaving well now. Thanks again.
Dear RBB
The function code you gave me is good but i cant call it. Im simply trying to calculate the log base 2 of 26 n save it to a register n_var. Please correct this code for me. Its as follows
module sample11(n_var);
output [15:0]n_var;
n_var = clogb2(26);
input [31:0] value;
integer i;
begin
clogb2 = 0;
clogb2 = i + 1;
end
endfunction
endmodule
Thanks alot
module sample11(v,n_var);
input  [15:0]v;
output [15:0]n_var;
wire [15:0] v;
reg [15:0]n_var;
reg [15:0]value;
always @ (v)
n_var = clogb2(v);
input [31:0] value;
integer i;
begin
clogb2 = 0;
clogb2 = i + 1;
end
endfunction
endmodule
it is a simple testbench:
module test();
  reg [15:0] v;
  reg i;
  wire [15:0] n_var;
  sample11 s1(v,n_var);
 initial
  v = 2;
  initial
  #2000 $finish;
 always
  begin
      #5 v = v+1;
  end
  always @ (v)
  $monitor ("log%d = %d", v, n_var);
endmodule
    UFK
Dear meher81
Thankyou very much for your code. It simulates great. I just have to figure out a thing or two in it. Thanks alot.
Im stuck in another little piece of code now. I wondr if you can help me with it. Its supposed to scan an array for 16 elements and calculate the maximum value. Its as follows:
module maxvalue(b_array);
input [0:15] b_array;
integer i;
reg [0:15] mxm;
initial
begin
mxm = 16'b0;
for (i=0;i<15;i=i+1)
begin
if (b_array > mxm)
mxm = b_array;
end
end
endmodule
I just cant figure out how to write the testbench for it. I gave initial values to the b_array in the tb as follows:
module max11_tb();
// Inputs
reg [0:15] b_array;
// Instantiate the Unit Under Test (UUT)
maxvalue uut (
.b_array(b_array)
initial begin
// Initialize Inputs
b_array [0]= 13;
b_array [1]= 1;
b_array [2]= 2;
b_array [3]=14;
b_array [4]=12;
b_array [5]=0;
b_array [6]=-1;
b_array [7]=21;
b_array [8]=12;
b_array [9]=2;
b_array [10]=-4;
b_array [11]=0;
b_array [12]=9;
b_array [13]=13;
b_array [14]=10;
b_array [15]=-2;
// Wait 100 ns for global reset to finish
#100;
// Add stimulus here
end
endmodule
It isnt giving me the largest value as expected.
Please let me know if you can find a solution to it. Thanks alot
Dear UFK
Verilog doesn't allow an I/O port to be a 2-D array.
but if it it is necessary, you could flatten your array into a vector and pass that through the port.
module maxvalue(
                b_array,
                mxm,
                reset
input  [255:0] b_array;
input reset;
output [15:0] mxm;
reg  [15:0] array [0:15];
integer i;
reg [15:0] mxm;
always @ (b_array)
	begin
   if (reset)
     mxm = 0;
  	{array[15],array[14],array[13],array[12],array[11],array[10],array[9],array[8],array[7],array[6],array[5],array[4],array[3],array[2],array[1],array[0]}=b_array;
	 for (i=0;i<16;i=i+1)
		 	if (array[i] > mxm)
		 	mxm = array [i];
	end
endmodule
simple test module
module max11_tb();
reg  [255:0] b_array;
wire [15:0] max;
reg reset;
maxvalue uut (
			 .b_array(b_array),
			 .mxm (max),
			 .reset (reset)
initial
  begin
    reset = 1;
   #10 reset = 0;
  end
initial
  begin
    #7 b_array = 255'd1;
    #10 b_array = 255'd2;
    #15 b_array = 255'd197879804;
    #20 b_array = 255'd200000000000000000003;
  end
always @ (b_array)
	$monitor  ($time, "maximum value component = %d", max );
endmodule
    UFK
Dear meher81
Thanks alot for your help. You just made my life easier :)
Dear meher81
I am using the code u helped me with to scan values in a bram and then calculate maximum value. I stored 16 values in a bram by a coe file. Now im trying to run the following code by invoking the bram (spiht_mem). Since i already gave the values in the coe file i have no clue what to write in the testbench. Can u please help me? Thankyou in advance.
The code is
module maxvalue( b_array,mxm,reset,addrA,clkA);
input reset;
output [15:0] mxm;
input clkA;
input [15:0] addrA;
Spiht_mem M1 (
.clka(clkA),
.wea(), // Bus [0 : 0]
.addra(addrA), // Bus [15 : 0]
.dina(), // Bus [15 : 0]
.douta(array)); // Bus [15 : 0]
integer i;
reg [15:0] mxm;
always @ (b_array)
begin
if (reset)
mxm = 0;
//[15:0] array[0:15]= b_array;
if (array > mxm)
mxm = array ;
end
endmodule
I don't know what you want.
I guess that you have stored some values in a file (as bram.dat) and want to apply them to your code, which detect maximum value. yes?
Hii meher81
Yes that is exactly what i want. I was testing my algorithm to work for 16 values initially but i wanted my code to work for as many values as i want, say for a 128 x128 image which means that if i load 16384 decimal values in my bram as a .coe file it should call the values from the bram and then scan for the maximum decimal value.
Btw if i call values from the bram using (.dout(w1[0:b]) where w1 is a wire do u think it will work?
Part of my code is like this
reg [31:0] LIS5a [1023:0];
FiveA M1 (.douta(LIS5a));
here FiveA is my bram in which i have loaded a .coe file of 1024 decimal values. I want to call those values so i tried moving them directly in to the reg LIS5a instead of using wire w1. Any suggestions or comments?
Thanks alot for all the help :)
Dear UFK
you can do this in a testbench. at first, store file content in an array using $readmemb. after that you can do, with the array elements, what you want.
meher81 said:
Dear UFK
Dear meher81
I did what u suggested and everything worked brilliantly, until i realized that $readmemh will not take negative hex values from my text file. Im back at square one now ! :(((( Do u have a solution to this problem?
Previously i tried using a bram, but i couldnt figure out how to move its .coe file contents in to my array.
Please help me.
And thanks alot for everything
Dear UFK
you should change your negative numbers to 2's complement format. (perhaps with MATLAB or manually!)
Hii meher81
I did change it to negative format (e.g -1 to FFFFFFFF) and it still isnt quite working. Please do me this big favour. Im posting my code, test bench and txt file. Can u plz run it and see the results? I know ull know wat im doing wrong.
module max_val(mxm,
reset
input reset;
output [31:0] mxm;
reg [31:0] Mem [0:3];
integer i;
reg [31:0] mxm;
initial $readmemh("D15.txt",Mem);
always @ *
begin
if (reset)
mxm = 0;
for (i=0;i<=3;i=i+1)
if (Mem > mxm)
mxm = Mem ;
end
endmodule
Testbench
module max_val_tb;
// Inputs
reg reset;
// Outputs
wire [31:0] mxm;
max_val uut (
.mxm(mxm),
.reset(reset)
initial begin
reset = 0;
#100;
reset = 1;
end
endmodule
and the text file
//D15 =
29B
043
FFFFFE72
FFFFFEE7
//667
//67
//-398
//-281
wat i figured is that if my text file has the following numbers in hex form i.e -10,-11,-12,10,11,12, the code simply ignores the positive values and computes the maximum of the negative values, for instance in this case it will return -10 which is the max.
Maybe ud know a solution.
And thanks a million for always coming to my rescue :)
module max_val (
				mxm,
				in,
				reset
input reset;
input  [ 31 : 0 ] in;
output [ 31 : 0 ] mxm;
wire   [ 31 : 0 ] in;
integer k;
integer i;
integer  mxm;
always @ (in or reset)
	begin
		if (reset)
			mxm = 0;
		else
			k=in;
		if (k>mxm)
			mxm <= k;
	end
endmodule
Testbench:
module max_val_tb;
wire [31:0] mxm;
reg reset,clk;
integer i;
integer input_data;
max_val uut (
			.mxm(mxm),
			.in(input_data),
			.reset(reset)
initial
	begin
		reset = 1;
		#2 reset = 0;
	end
initial
	clk =0;
always
	#5 clk=~clk;
initial
	i=0;
always @ (posedge clk)
	begin
		input_data = Mem[i];
		i = i+1;
		$monitor ("max = %d, input=%d", mxm, input_data);
	end
endmodule
Added after 24 minutes:
I did that same as you, but in this way, after the reset, mxm is set to zero. therefore this code neglect negative numbers. to solve that, you can do same as below:
module max_val (
				mxm,
				in,
				reset
input reset;
wire   [ 31 : 0 ] in;
integer k;
integer i;
integer  mxm;
	begin
		if (reset)
			mxm = 32'h80000001;
		else
			k=in;
		if (k>mxm)
			mxm <= k;
	end
endmodule
Testbench:
module max_val_tb;
wire [31:0] mxm;
reg reset,clk;
integer i,m;
integer input_data;
max_val uut (
			.mxm(mxm),
			.in(input_data),
			.reset(reset)
initial
	begin
		reset = 1;
		#2 reset = 0;
	end
initial
	clk =0;
always
	#5 clk=~clk;
initial
	i=0;
	begin
		i = i+1;
		m=mxm;
		$monitor ("max = %d, input=%d", m, input_data);
	end
endmodule
Dear meher
Maybe you could solve another one of my neverending problems.
Im posting my code below. If possible, Please run it and see if it can be altered to function the way i want. My code isnt reading negative hex values. It only gives correct results for positive hex values. Can anything be done about it?
1. I have two arrays LIP and LSP. readmem will put memory values into LIP.
2. The code is supposed to read the four values from LIP and compare with the parameter T.
3. If greater than T, then move values to LSP.
4. If less than T, then leave it in LIP
5. The bit counters seem to function fine.
My code is
module test();
reg [31:0] Signbit_ctr;
reg [31:0] Bit_ctr0;
reg [31:0] Bit_ctr1;
reg[31:0] T=32'h00001000; //decimal 4096
integer i;
integer k;
reg [31:0] LIP [0:3];
reg [31:0] LSP [0:1023];
initial $readmemh("D16.txt",LIP);
initial
begin
Signbit_ctr = 0;
Bit_ctr0 = 0;
Bit_ctr1 = 0;
end
always @ (LIP)
begin
for(i=0;i<=3;i=i+1)
if (LIP >= T)
begin
LSP = LIP;
Bit_ctr1 = Bit_ctr1 + 1;
Signbit_ctr = Signbit_ctr + 1;
end
else
begin
Bit_ctr0 = Bit_ctr0 + 1;
$display("%d:%h",i,LSP);
end
end
endmodule
and the text file D16 is
12F2
FFFFFD3E
FFFFFF78
FF
Thankyou so much
Dear meher81
I need you help.
Im posting a code which u wrote for me a few months ago. Its a part of my encoder. It just wont synthesize. Maybe you can help.
The code is
module Log_max(v,n_var,T);
input [31:0]v;
output [31:0]n_var;
output reg [31:0] T=0;
wire [31:0] v;
reg [31:0]n_var;
reg [3:0] base = 2;
always @ (v)
n_var = CLogB2(v);
always@(*)
begin
T = base ** n_var;
end
//ceil of the log base 2
function integer CLogB2;
input [31:0] Depth;
integer i;
begin
i = Depth;
for(CLogB2 = 0; i > 1; CLogB2 = CLogB2 + 1)
i = i >> 1;
end
endfunction
endmodule
Testbench
module Log_max_tb;
// Inputs
reg [31:0] v;
// Outputs
wire [31:0] n_var;
wire [31:0] T;
Log_max uut (
.v(v),
.n_var(n_var),
.T(T)
initial begin
v = 32'h00000B43;
end
endmodule
It gives correct result but cannot synthesize. Please help
Thankyou
