How to initialize PIC16F877 in ADC mode using microC?
theblackmac
Newbie level 3
hi
i'm working on a project that is a Digital relay to for an over current and negative sequence in a three phase motor.
the thing is I haven't worked on a PIC nor on the microC before, although I toke C language a while ago.
i need to take an Analog input to the microchip.
how can program initialize the pic to be in ADC mode.
P.S. I've already got the development board.
thanks
PIC16F877 and microC
mikroC has excellent help with lots of sample codes.. check them out
Re: PIC16F877 and microC
Check the mikroC manual for teh ADC library @ **broken link removed**
thanks
but this is really deep and i don't have much time, do you have already written examples, that would help.
thanks again
It has an example, you can start from it ISA.
dear friend
if you don't have time, how you expect your project works fine?
till this time you could have go through the help file and the datasheet, you would be able to fine the solution
you did not specified which channel you are going to use, then how you expect others to provide you help?
please try something and come with the code that you wrote,it will be easy to clear the mistake
regards
ml
I'll try something and I'll get back to you.
thank you.
can anyone tell me how can i make source code with mikroc for thic schematic??
You are using a 5v power supply, so your ADC reference is 5v. So, since you are using 10-bit ADC (you can configure to 8-bit if you like), the maximum value will be 1023 which will be achieved when input = vref = 5v. So anything you read will be on a scale of 0 to 1023 for 0 to 5v. It follows:
Val(ADC) = (Input Voltage / Ref Voltage) * (2 ^ Resolution)
So,
Val(ADC) = (Input Voltage / 5) * 1024
So, you read the ADC channels as:
unsigned int AD1;
unsigned int AD2;
AD1 = ADC_Read(0);
AD2 = ADC_Read(1);
AD1 and AD2 now hold digital values for corresponding analog values at ADC channels 0 and 1 respectively.
Ignoring channel 1 for the moment, let's consider you have 35'C temp. So LM35 reads
35 * 0.01 = 0.35v
. This will be read by PIC as
(0.35/5) * 1024 = 71
AD1 stores 71.
Now you need to convert this such that you can show the value on the 7-segments.
Hope this helps.
Tahmid.
