himrwt
Junior Member level 2
i am trying to use ultrasonic transducer module for distance measurement. i am using a three pin module. for triggering ultrasonic module i pull data pin to high for 1ms then push it to low. then i measure the time for which module pulls its data pin high. but its not responding. it does not pull its data pin high after triggering.
is the module defective?
what ca be the probable reason for it not responding?
