+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 3
    Points: 518, Level: 4
    Join Date
    Apr 2010
    EE
    Posts
    Points
    518
    Level
    4-20mA Loop powered isolated transmitter
    Hello All,
    I am working on a circuit design for isolated 4-20mA transmitter. I found an example circuit and try to simulate it in spice. Receiver functions very well, transmitter has some problems. The current flowing thorugh loop is always around 3.4mA. I couldnt find out why: Can somebody help me?
    Between +ILOOP and -ILOOP there is a 24V voltage source in spice simulations. I measure the current there. Input is 0V to 4V.
    Thanks for any help.
    Regards
    •   AltAdvertisement
  2. #2
    Super Moderator
    Points: 50,045, Level: 54
    Achievements:
    7 years registered
    keith1200rs's Avatar
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    50,045
    Level
    54
    Your photodiode circuit doesn't look right. There will be a voltage drop across R5 and this voltage is fed into the inverting input of the opamp through R3. This will take the inverting input below the opamp GND. It will not work with inputs below ground. My guess is your transistor will always be ON, althiough I would have expected a lot more than 3.4mA from a 24V source in that case.
    When the photodiode voltage is high enough the transistor would turn off.
    Keith.
    I started life with nothing and I've still got most of it left. (Seasick Steve)
    •   AltAdvertisement
  3. #3
    Newbie level 3
    Join Date
    Apr 2010
    EE
    Posts
    Points
    518
    Level
    Re: 4-20mA Loop powered isolated transmitter
    Hi Keith
    Thanks for recomm. I quickly built the circuitry on breadboard. There was continuously ~28mA on circuit.
    I guess the problem (as you said) the input side of opamp. Thus I swapped the inputs. Vin+ should be above, as the voltage difference is going to be positive and output of LM158 turn on 2N3904. However I am observing oscillation as attached. BJT is turning on and off and thus whole systems is modulated. Do you see why or how can I avoid it?
    Regards
    1 members found this post helpful.
    •   AltAdvertisement
  4. #4
    Super Moderator
    Achievements:
    7 years registered
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    50,045
    Level
    54
    My guess is that you need a very large capacitor on your supply. When the transistor turns on the power supply collapses so the transistor turns off etc. Try 100uF instead of 100nF for the decoupling across the opamp power supply.
    Keith.
  5. #5
    Newbie level 3
    Join Date
    Apr 2010
    EE
    Posts
    Points
    518
    Level
    Hi Keith,
    Thanks. I found also another problem. The polarity of loop powered LM158 should be swapped and also capacitor (1nF) should be kept at Vin- for feedback. When I fine tune few resistor values, the system functions perfectly as 4mA-20mA loop transmitter. So it is an fully isolated 4-20mA.
    Tomorrow I am going to give a try on breadboard at university's lab. Hope it functions as simulator shows.
    Regards
