Results 1 to 11 of 11
    Junior Member level 1
    Points: 2,160, Level: 10
    elmahboule's Avatar
    Jul 2008
    17
    2,160
    10
    reverse the sign of the direct current
    hello
    I want to reverse the sign of the direct current
    I want to reverse +1 VDC to -1Vdc
    Help me please
    Points: 50,045, Level: 54
    keith1200rs's Avatar
    Oct 2009
    Yorkshire, UK
    10,877
    50,045
    54
    A little more detail would be useful e.g. do you want just a small current or several amps?
    Anyway, assuming you don't want too much current, and inverting opamp is one way.
    Keith.
    I started life with nothing and I've still got most of it left. (Seasick Steve)
    elmahboule's Avatar
    Jul 2008
    17
    2,160
    10
    Re: reverse the sign of the direct current
    thank you my Friend "keith1200rs"
    I have a +1VDC voltage, so from the this tension, I want the -1VDC, to change the direction of rotation of a drive speed.
    So I want to reverse the voltage from +1VDC to -1VDC
    Oct 2009
    Yorkshire, UK
    10,877
    50,045
    54
    If you are reversing a motor drive, can you not simply use a relay?
    What current?
    Keith
    elmahboule's Avatar
    Jul 2008
    17
    2,160
    10
    see my freind
    the drive speed has only 1 inbut of direction, if the value is +1VDC we have a direction, if it is -1VDC we get the second direction.
    I have 2 Potentiometers, the value of output of the first Potentiometer is OK " +1VDC "
    And I have also the value of the second Potentiometer is +1VDC, But I need it -1VDC
    Points: 20,466, Level: 34
    Apr 2008
    EU
    2,332
    20,466
    34
    Hi elmahboule,
    in that case you have two possibilities;
    1,
    the second potenciometer is to supply from a opposit polarity as the first one!
    2,
    if you dont have an inverted voltage for your second poti`s supplying= use a voltage inverter amplifier; BUT for that you NEEDS a SUPPLY WITH +/- voltages...
    K.
  7. #7
    elmahboule's Avatar
    Jul 2008
    17
    2,160
    10
    thank you " karesz "
    Now I understand
    I must use the am_op
    as this
  8. #8
    Oct 2009
    Yorkshire, UK
    10,877
    50,045
    54
    Quote Originally Posted by elmahboule
    Now I understand
    as this
    Yes, but equal resistor values to get a gain of -1.
    Keith.
  9. #9
    elmahboule's Avatar
    Jul 2008
    17
    2,160
    10
    yes " keith1200rs "
    R1 = R2
    thank you, But I do not know the picture of integrated circuit
    So can you give me the picture of this integrated circuit. " am_op "
  10. #10
    Advanced Member level 3
    Points: 7,585, Level: 20
    Dec 2004
    759
    7,585
    20
    yes " keith1200rs "
    R1 = R2
    Hi elmahboule,
    You can use commonly available LM741 and wire it up like the picture you posted above.
    Refer to datasheet of pin description: http://www.national.com/ds/LM/LM741.pdf
    Good luck
  11. #11
    Oct 2009
    Yorkshire, UK
    10,877
    50,045
    54
    It would be useful to have a bit more information - there may be an easier solution. For example if you just want +1V or -1V then an analogue switch may be all you need.
    Keith
