(From one of the PDFs below)
Vin - inverted by M1 - creates an appropriately modulated current through M1 & M3, which is mirrored (due to the common Vg of M3 & M4) to an - again inverted - current through M4 & M2. At their connection - Vip here is inverted only once - the output signal is single ended. There's a 2nd inverter stage (M7, M6) with constant current load (M6).
Find more differential to single conversion schemes in the PDFs below!
