+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 1
    Points: 476, Level: 4
    Join Date
    Apr 2010
    Indonesia
    Posts
    Points
    476
    Level
    Using slide switch as a manual clock in spartan 3E starter
    Hi guys...
    I want to ask about how to make manual clock in spartan 3E starter kit...can we use slide switch as a manual clock?? ask example, i want to use it's clock to simulate 4 bit shift register..
    i need a manual clock,because data input is a serial data..so,it is impossible to use internal clock (50MHz) cause I insert the serial data input manually..
    thanks...
    •   AltAdvertisement
  2. #2
    Full Member level 1
    Points: 1,125, Level: 7
    user_asic's Avatar
    Join Date
    Nov 2009
    Canada
    Posts
    100
    Points
    1,125
    Level
    7
    Instead use the push buttons and have the register latch data when its pulsed. I think there are 4 such buttons on the Spartan 3E board. Basically, you can make your trigger condition whatever you want it to be, not just the on-board clk.
    •   AltAdvertisement
  3. #3
    Member level 3
    Points: 889, Level: 6
    Join Date
    Feb 2010
    Posts
    57
    Points
    889
    Level
    Don't forget to debounce/deglitch. Manual switches and pushbuttons are noisy.
