ybhphoenix
Newbie level 3
help. I want to use command line in the linux shell to call momentum simulation (S-parameters).
I want to import the GDSII file into the ADS,use special substrate file, add the port (at the needed position)to the dsn file, then do the momentum simulation. I need do all the things before in the command line(shell).
I know it may relate with the "momEngine" "hpeesofemx" "momServer" "rfdeMomWrapper"(/ads/bin/), I can see the only demo in the ADS "momAutoTest.ksh".
Thank u so much for the reply~
