Can I send 2 adc to PC with serial?
Login383
Newbie level 3
Send 2 adc to PC?
Help me.
I am use AVR ATMEGA 8535 and ADC from PORTA.0 and PORTA.1.
How the program?
Thanks.
Re: Send 2 adc to PC?
Set the AVR’s UART for, say 9600, 8-bit, no-parity, 1-stop ..
https://extremeelectronics.co.in/avr-tutorials/using-the-usart-of-avr-microcontrollers/
At the PC end, open Hyperterminal and set for the same as above ..
Can I assume that you don’t have any issues with the hardware connection ..
The link below shows how to use the ADC:
https://extremeelectronics.co.in/avr-tutorials/using-the-analog-to-digital-converter/
You can send string that contains raw data or you can convert raw data into ASCII so when it appears on the hyperterminal screen it is easy to read ..
At the end of each string add “0D”h and “0A”h, this combination of control characters will return the cursor on the PC’s screen to the beginning of the next line ..
Example:
<ADC1H><ADC1L>,<ADC0H><ADC0L>, 0Dh, 0Ah
Rgds,
IanP
:D
Example:
Rgds,
IanP
:D
In the PC, how to get data form adc0 and adc1 (split data from adc0 and adc1)?
