gokulfun
Newbie level 3
[/code]Hi all,
Am new to VHDL and this forum.
When executing my VHDL code am getting following warning "Inferring latches for signal or variable "datain_mem" which holds its previous value in one or more paths"
"Inferring latches for signal or variable "datain_reg" which holds its previous value in one or more paths"
my code is
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity datapath is
port( reset, clk, start: in std_logic;
mainout: out std_logic_vector( 7 downto 0 )
end datapath;
architecture struct of datapath is
component controller is
port( clock,GO,rst: in std_logic;
wr,memdrive,aludrive,ld_x,ld_y: out std_logic;
funct_in:in std_logic_vector(7 downto 0);
addr: out std_logic_vector(7 downto 0);
funct: out std_logic_vector(2 downto 0)
end component;
component memory is
port ( clock,rst,wr,memdrive : in std_logic;
data_in,address : in std_logic_vector(7 downto 0);
data_out : out std_logic_vector(7 downto 0)
end component;
component alu is
port( reset, clk, l_x,l_y,aludrive: in std_logic;
xm,ym: in std_logic_vector( 7 downto 0 );
func_m: in std_logic_vector( 2 downto 0);
aluout: out std_logic_vector( 7 downto 0 )
end component;
signal address: std_logic_vector( 7 downto 0 );
signal wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y_s: std_logic;
signal funct_s: std_logic_vector(2 downto 0);
signal mainbus : std_logic_vector( 7 downto 0 );
signal datain_mem ,datain_reg: std_logic_vector( 7 downto 0 );
signal dataout_m,math_out,dataxout,datayout : std_logic_vector( 7 downto 0 );
begin
Control:controller port map(clk,start,reset,wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y_s,mainbus,address,funct_s);
Mem: memory port map( clk,reset,wr_s,memdrive_s,datain_mem,address,dataout_m);
Arithlogic: alu port map( reset,clk,ld_x_s,ld_y_s,aludrive_s,datain_reg,datain_mem,funct_s,math_out);
mainout <= math_out;
process(clk,wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y_s,mainbus,dataout_m,math_out)
begin
if (wr_s = '1') then
datain_mem <= mainbus ;
end if;
if (memdrive_s='1' ) then
if (wr_s = '0') then
mainbus <= dataout_m;
else
mainbus<=(others=>'Z');
end if;
if (ld_x_s='1' or ld_y_s='1') then
datain_reg <= mainbus;
end if;
elsif(aludrive_s = '1') then
mainbus <= math_out;
else
end if;
end process;
end struct;
Can anyone pls help me resolve this issue....
Thanks in advance
