venuselectronics
welding
how to weld copper to stainless steel(304)
elcaminokid said:I have been working with this for some RD, I'm using a lumonics laser on a custom set up CNC guided motion system. I have been able to weld high purity copper tube of .25in diameter into a 304L sst plate. It is certainly prone to cracking without proper adjustment of power and overlap between the materials. I am very close to a full weld without cracking, about a 90 percent arc without cracking. As pictures the weld width is .040 in
