Transmission mictrostrip line to coupled line ?
mauloftin
Full Member level 6
CZ
can tell me somebody, how can I do transmission mictrostrip line to coupled line? Have you some theory? Exactly I need transmission mictrostrip line to differential line.
Thank!
Exactly, if I have SAW filter with balance input/output (differential impedance) - how can I use microstrip line as source?
is my question stupidity or is it so difficult ? :)
Or my english is so horrible? :)
Are you sure that your SAW filter requires differential input/output?
You need to use something called a "balun" at the input and at the output. You can make one from coupled lines (like a marchand balun), you can make one from lumped elements, and you can make one from a ferrite tranformer with wire windings.
The best performance would be a transmission line balun, but it will be long. I would probably go with a lumped element balun myself.
Added after 4 minutes:
such as in the following files:
