How to calculate dynamic power and static power using Spectre ?
prakashreddy
Newbie level 6
How to calculate Dynamic power,static power using spectre
Re: spectre calculation
How would you calculate them by hand?
If you have the formula you should write an ocean script(actually just a command) or ask the Calculator in the GUI. As far as I know Spectre is a simulator. For post processing the results you need other programs.
spectre calculation
Eldo gives you the static power consumption. In order to calculte the dynamic power, calculate the total power consumption (U*I) and then subtract the static power.
Whith spectre I have no Idea.
hello , you can plot VDD(t)Idd(T) using tran analysis , and then using calculator , calculate average of vdd(t)Idd(T) , it gives you dynamic power of the gate, but for static , i have no idea
