Can we convert MATLAB code into an .exe file ?
sudan
Member level 5
chennai
Suggession for MATLAB
Hai Everyone,
Can we convert MATLAB code into an .exe file ? ie: like C Program. Please suggest me !
Thank you,
Swamy
Re: convert MATLAB code into an .exe file - Regd.
Hai Ali,
Thank you for your suggession. Movere, I have tried but I can't able to get
convert matlab file into an exe file.
If you know the procedure please inform to me.
Thanking you
Swamy
Please,
Specify the mcc command syntax you used.
mcc generates exe files. I used it my self :).
Amr Ali
Hai Ali,
I tried different commands present in mcc. For example mcc -m test.m
But it is giving the following error...
Error: File "test" is a script M-file and cannot be compiled with the current Compiler.
Please tell me what way I have to solve ?
Thank you,
Swamy
You have to specify the name of the output file and its extension as .exe
Amr Ali
